B
bobbyp
Guest
Does the iac tables require crank signal to work? I am trying to
check the iac motor visually (unbolted but still wired) and can't
seem to get it to respond. I have set the "p" & "d" gain to 255
(for max movement). The start iac and throttle follower tables
have been adjusted from max to min settings several times.
Nothing seems to make a difference.
I can get the car to idle using ve numbers, but can't get it to ever
read anything other than max lean at idle. The o2 sensor seems
to be working correctly.
Gut feeling is that I have a vacuum leak but can't find one, the
only thing that I can find is the iac seems to be stuck open.
By the way the iac is brand new unit from fast w/ the ford adapter.
Thanks, any help would be appreciated
