I agree cylinder pressure is cylinder pressure but the dynamics to create that pressure have to change dramatically imo... adding 30 percent more of a fuel that is harder to ignite has to really limit a stock ignition system... which I found out, at least on my car that after 16lbs. of boost I was done
In my experience I think you and Matt are right-on with your comments and conclusions and we have been dealing with this on e-85 performance applications for a couple years with limited success.
It is ironic that just this AM, a test drive in a car we have been fighting high RPM and boost issues for a year and a half, it has proved to my satisfaction just what you both, and others, have stated!
The car is a turbo T with a 270 cu.in 4.1 with TA alum heads and a TE-45A turbo. It would pull like crazy to 10 psi, then break up. We installed a new $300 module and coil and it then went to 12 psi. I dug out an original 1987 module/coil and it then got to 15 psi.
Today with the TR6 even at 20 psi on the interstate at 100+ MPH, it was still pulling strong!
Last year I converted my race car from 116 octane to e-85 and never had this issue, BUT it uses a distributor with a MSD 4AL which puts out LOTS of spark.
The many other local e-85 conversions we have done are street cars and are not at the 500-600 HP level, so we have not had this problem for the reasons mentioned of cylinder pressure, and the larger amount of e-85 fuel injected needed for the additional HP.
When this issue first came up last year, we tried 1/2 dozen stock module/coil units, and then 3 or so new ones which made this very frustrating as they would not perform?
We also tried other parts like new crank and cam sensors, new harness, injectors with no avail?
A conversation with John Spina of Casper's last week was very enlightening as he pointed out the new modules cannot be produced exactly like the originals because many original components are no longer available, so substitutions are made.
The new units work OK on the street cars, but modified higher HP demands are usually not met with them?
Fortunately the turbo Buick community has people like Bob Bailey to provide us with products like the TR6 that far surpasses what the factory parts could do in their day.
