Detomaso71
- Feb 14, 2010
I have a ignition break up issue that starts right At 4500 rpm and the rev limiter on the fast and bob bailey are set way above that. I have replaced coil pack and module and plugs. Even borrowed a friends coil pack module to be sure I didn't buy a bad one
Car has new fuel system and logs show appropriate fuel pressure at boost and ignition is standard GN coil pack module and bob bailey box and fast XFI
I had a local GN "veteran" drive car who thinks acts like a coil pack issue but again I have used 3 different coil pack/modules in last month and no difference
How do I unplug or by pass the bob bailey box to run
car without it to eliminate it as culprit?
Anything else it could be?
Car ran great in BG last October sat over winter and the problem was there after winter and both street and race tune are doin it on different types of new gas and all tuning was by Cal
I unplugged both plugs ins on bailey box but then will not start so I'm trying to eliminate it and attack the problem by elimination method
Thx
Thx
