eiuskoalman
- May 28, 2001
lately i've been getting more knock than usual at WOT along with a little smoke during the knock. plugs look good and the wires are only a year old w/less than 5K on them. i've got a feeling it may be time for a new coilpack/module but i dont know for sure. it is the original coilpack, still has the sticker with the date on it (XX/XX/86) and i assume the module is also original. these 2 parts have some serious experience, 115,000 miles worth to be exact. now, i know there is a way to test the coilpack. is it worth testing at this point and if so does it require any special tool to do so? details to sort out this problem are as follows:
stock turbo, IC, inj
307 pump with hotwire and adj. regulator
thrasher 92
currently running 17 lbs of boost
50/50 mix of 93 and 100 octane UL
newer afs 20 o2 sensor
good tps and iac settings............
the car is in a good state of tune with the exception of the knock at WOT. i'd think i should be able to run 17 lbs of boost easily with the fuel mix i'm using??? any help appreciated.
thanks again, aaron
thrasher 92
thanks again, aaron
