May 10, 2008 #1 B buickGTP Member Joined Sep 22, 2006 Messages 92 Can the signal that the ignition module sends to the tachometer be read by a regular voltmeter and is there a ideal voltage. Thanks Steve
May 10, 2008 #2 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 It's not a voltage, it's a pulse train.
May 10, 2008 #3 B buickGTP Member Joined Sep 22, 2006 Messages 92 pulse train Thank you for the responce. Do you know of a way to determine if the pulse is reaching the tach I am trying to determine if there is a problem with the tach,wiring or the ignition module Thanks again Steve
May 10, 2008 #5 B buickGTP Member Joined Sep 22, 2006 Messages 92 Turbo dave and 85hot-t thanks for the help
