Ignition problem or ?
anders
1989 TTA
Hi!
Run the car for the first time after vinter.
Run great for 10-15 minutes the i stepped a little harder on trottle a few times,did gtreat but after third time it backfires and did not responce to trottle just backfires,had to run it on idle back to the garage.
t runs fine at idle but as soon ju give it a little trottle it starts to wobble and if you continue to give it more trottle it backfires by the exhaust.
Any suggestion?
I have change chip but it justgot worse.
Anders
Have you checked all the IC hoses and vacuum lines? How is the fuel pressure and old fuel? Fuel filter ?
Fuelpressrr does not drop,added nex fuel yesterday,will chech IC clamps again
3.5 MAF. Translator + ver 6
Back fire through exhaust: what's the O2 when it does?
Check grounds back of the head and also make sure the coil/module is tight on the intake.
Tps is ok
Are the coilpack grounded by the intake,it missing a bolt but still sitting tight
The pipe from inter cooler to throttle body.
Drain out the fuel and put some fresh fuel in. Don't want to go into boost with old fuel anyway.
Pipe is ok,now it wont start at all,going to pull the plugs.
Thinking of MAF or coilpack failure
No spark
How can i check that the ecm makes signal or how can i check the coilpack if possible.
