I'm getting a wrong reading for the TPS SENSOR
anthony mendoza
when I put the muilty meter to adjust the tps sensor to 0.40-0.46 volts it reads 41.0 why is that and what am I doing wrong???
Sounds like you have your meter set to read mv ( millivolts ). If it 41 is good for idle.
41 mv is the same as .41 v
Many multimeters have range buttons on them also that moves your decimal and changes your value.
Put your meter on your battery (or the 5v reference line) and push the range button (or turn the knob) until it looks right.
Then back probe the output signal.
Also, stand by for a bunch of people to tell you to buy a Scanmaster :D
