Turbo Riviera
- May 29, 2001
After all these years, I am FINALLY getting back to work on my '84 GN. This car has sat since 1997 when I bought my Riviera and '87 GN.
I want to make a quick street car that doesn't knock, runs on pump gas, is quiet and idles good.
My old combo ran 13.20's @ 101 with 210/205 cam, LT headers & DP, ported intake and heads, a TH-400 trans, @ 15 psi boost. This was back when I had no clue how to keep head gaskets on hot-airs! LOL This thing was pinging from the starting line to the finish line and more than likely it pinged on the return road too! needless to say, we all know why there's a couple of chunks of piston missing on #1 and #3. Since this motor is kind of useless at the moment, I'm snatching the motor from my Riviera which is all stock except for a cam and installing it into my GN. I will not be re-using any parts from the old combo.
The problem with this motor is I run it at 21 psi (and race gas) to get the desired performance from it in my Riviera. I want to keep pump gas in it at all times. So I'm left with using alcohol, propane, or an intercooler.
I have all the parts to bolt a stock '86-'87 intercooler on, but I'm not very convinced it will do the job @ 21 psi.
Money is an object here. I really don't want to toss a bunch of $$$ at this car if I don't have to. (I did that many years ago!)
Finally, a question in this thread... Should I go intercooled, or go with a decent alky kit, or pony up the bucks and get the pro-pain kit?
The motor typically goes 14.30's in my Riviera (front drive and 3800 pounds) at my altitude (4400 feet). I figure it should pick up enough in weight and being in the rear drive GN, to go 13.90's pretty easily just as is w/ race gas. I'd like to keep that performance if possible on pump gas.
I don't want to have to make excuses for why I can't race someone at a stoplight... I'm looking for the best way to replace race gas.
