I'm stumped..
rob350
Well, im clueless with whats wrong with my car, so maybe you guys can help me out. I have a miss that starts at about 5 PSI. The car will miss when the motor is cold or warmed up. I changed crank sensors, unplugged the cam sensor to see how it ran, tried 2 different ignition modules, 2 different coil packs, put my stock 85 ecm back in with the 85 maf and still had the same problem. I also replaced all the spark plugs but not the wires yet. The wires are AC Delco, and I out them on less than 2 years ago. I check to make sure my 2 week old Walbro pump wasn't crapping out, and the fuel pressure was good. Everything looks good on WinALDL. Any suggestions?
What did your plugs look like when you pulled them? Were they a brownish color, black, or moist at all??
