After researching and finding my orginal instructions for my Turbonetics "Dial a Boost", this is what I found. Nothing about slow spool up but rather spikes. Below is a quote from the following webpage under the "Dial a Boost" section:
"Manual boost controllers are also very prone to boost spikes. This occurs when the VBC is open all the way and small diameter hose is being used. The boost pressure builds faster than the hose can flow which lets the turbo spike up big boost numbers until the pressure fights its way through the small hose to the diaphragm, then the boost drops back down. This is a dangerous situation since the spike can blow up your engine before you know what happened. The best way to minimize spike is to keep the manual boost controller located under the hood with as short a length of hose as is possible. This is easily demonstrated by you picking up a piece of ¼" hose 4 feet long and trying to breath through it. Go ahead, try it. Pretty tough isn't it. Now cut the hose in half and try it. Much easier. Your turbo and wastegate feels the same way.'
I didn't notice spikes when I used to use the in car controller with my GN but the I was also using a Deltagate.
I am using the Hallman Pro MBC. It's mounted off the turbo heat shield. No issues with spike.
I cant' see how using a in car controller will change anything as long as it's a mechanical cable.
