I've recently noticed that my A/F table is showing the 3-bar MAP range when it should be showing 2-bar. 2-bar is what is programmed into the config section, and when I try the adjustment on the computer (unhooked to the car) it makes the correct changes to the graph. However, plugged in it stays at 3-bar. I assume this is throwing off my A/F tuning by not giving me as much control as I need. I've tried this with 2 separate laptops and a desktop, all with the same result. Is this a glitch? Is there a fix?
