Bryan, I agree with having more intake duration for a turbo engine. But it would be good to see some actual test results to confirm what we believe, and nobody ever does that for the turbo Buick. You can pick up a magazine at any news stand, and read dyno test results for Hondas, or small block chebbies, or Mustangs, where they swap parts and compare cams, or intakes, or air filters- whatever. When you said you had done the R&D years ago, I thought maybe you had some test results. GMHTP magazine did some back-to-back tests on intercoolers, but they kind of fudged the results, as I remember. Race Jace did those flow tests for the power plate, and that was good. But I've never seen any tests for cams in a turbo Buick.
As to John's theory about the bigger exhaust valve, it seems to me that at part throttle, before boost builds, the flow is going to be low. At low flow, small valves and ports, along with short duration, is needed to keep velocities up, to give good throttle response. So I'm not sure the bigger exhaust valve would provide any benefit.
