Can I get a little info on this setup? I will be changing things around this winter and want to know the scoop on this setup.
Currently, I have a stock ECM, 3.5" LS1 MAF sensor, Trans+ and extender chip (512gps version). I was going to step up to the new Extender Extreme (756gps version) since I have already maxed out the 512. But I might switch to this MAFless M.E. setup.
How does it work? Is there a built-in fuel curve? How does it compensate for fuel if it cannot read the amount of air going into the motor? Do you need a WB02? What about the stock O2? What is the price on this setup and what is all that is needed? My car will be a high-mid10 next year. It is currently a 11.10 car. Also, will it work with 65lb injectors? What injectors is it availible for?
I NEED INFO!!!!!! Thanks!!!!!!
