injector bench test
crashedout1
Going through the whole car how do I bench test the fuel injectors also got a line on a good used 87 ecm and harness I have 87 crank sensor and coil/ module stock harness is done price on the 84/85 harness is insane and since I have to get a new turbo I can't afford a new harness any help is highly appreciated
Why do you wanna change the harness what else do you plan on converting? You may not need it but if the price is right I wouldn't hurt to have one in your inventory
Engine is out and 84 harness is shot I cant afford 84 harness gotta punch out the cylinders and buy a new turbo or get this one rebuilt no money for a 800$ caspers harness I just want a good harness
Makes sense, you do know those computers are at the local junkyards all day long, for like 25$-30 the one you plan on buying is no good unless the chip matches your set up/injectors there are plenty of cars Gn made that came with the ECM ur looking for just swap the calpack from the old ECM and order a chip for your car done deal
