Injector Rubbers
Spooling
Finally got my shit all back together and went to fire it up - and after priming the fuel system, I noticed fuel smell. Sure enough one or 2 of the injector seals are leaking - seems to be leaking where they meet the fuel rail and not at the intake manifold.
Curious how long the injector seals last - and I assume it's probably best to do the upper as well as the lowers.
I can't remember - are they the same size O-Ring for both uppers and lowers?
I really find it ironic that I have a leak now - as I left the injectors bolted to the intake manifold during my R&R - and they did not leak back in December - before I disected my stuff.
Do the local Auto Parts Doosches carry new Injector seals? Should I use any "lube" on them before re-inserting them? Maybe some Trans Gel?
Many Thanks !!!
Advance and Autozone carry the O rings, same size top and bottom. Fel Pro part number ES 70599
Bryan
And yes, use a little vaseline on them during install, top and bottom
