Guys - I am running a PTE 64E turbo P-trim with PTE 63 exhaust housing. Current injectors are 55 lbs - with a single XP plus pump I was only able to run 19 lbs of boost to keep O2(s) at 760 and EGT @ 1600. Have purchased double pumper from RA - do you think this pump will keep my fuel cruve up with my turbo to allow boost of 26-30lbs??? Or should I also step up in injector size - 73 lbs???
Thanks for your thoughts
James
James
