Injectors Not Pulsating
85typet
hello guys i just bought a 86gn.car has been sitting for a couple of years and i replaced new fuel pump new filter and pulled coilpack & module,computer,fuel rail& injectors crank and cam sensor from my other car.the car is getting 40 psi to the rail but the injectors aren't pulsating if i spray starting fluid in tb car starts but wouldn't stay running.
What chip is in it? Could be an anti theft routine in the chip
Did you set the cam sensor properly?
TurboTGuy thinks I should cut it the F loose
Injector harness pluged in and cam senso ris pluged in and set properly spray starting fluid in the tb and it starts
In your first post you mentioned the coil pack and ignition module. Are they good? And are they installed? Ground comes thru base plate and it needs to be bolted down. Plug in to ignition module is good?
How did you confirm they weren't pulsing. Voltmeter at harness?
Thank god for the simple stuff. Glad you are back on the road.
currently cutting it the F loose
Yup this car had been sitting up for 10 years so I just finally got the trunk open and things got interesting
