SignUp Now!I need the left inner fender for a 84 gnI have both, passenger and driver.
What is your location
May be worth a lookThanks for letting me know. I know they are hard to find. Mine has had a big hole hacked out, but I may try to patch it. I'm going to keep looking.
Thanks again.
the one in that listing is fine if you aren't running the stock air filter box but thats not a turbo fender liner.May be worth a look
Link: GN OEM Inner Fender Well
Ridgeland, MS. 39157I have both, passenger and driver.
Learn something new every day. Thanks for the education.the one in that listing is fine if you aren't running the stock air filter box but thats not a turbo fender liner.
the turbo has a swoop in beside the battery area where the factory air box goes , also will be stamped turbo near that area
the passenger sides are different as well in the area between the ac and the reservior , the turbo liner is smooth , the NA carb liner has a protrusions for the map/baro sensor to bolt to
I have never considered shipping something like an inner fender well.Passenger side shipped to 79938? Only if it’s available
I have a good left inner fender from an 84 GN if still looking. 18080.I need the left inner fender for a 84 gn
