innovate wideband users....installation (wiring) question
ryan319
i'm installing an innovate lc1 and hooking it up to a powerlogger. my question is around the wiring of the wideband. i'm curious where you grounded the wideband and where you hooked for the power source. my o2 sensor is in the downpipe and i was planning to ground everything to the block and pull the power from the fuse panel. i guess to do that i would have to strip the sheath on the wires way back so i can seperate the wires more. but if i ground the sensor to the block, it seems like it would be a pain to get to the LED and pushbutton. just looking for some ideas on where you ran your wires. thanks.
