b4black
 - May 24, 2001
A long time ago I had an innovate LM-1.  It was hard to read while driving, and cumbersome to record.   Then it died.  I really like the AEM gauge I have in my '02 GS, so I installed the same gauge in my '83 TR.  I didn't want another gauge on the a-pillar, so I can up with this.
It's the gauge mounted in a PVC pipe, painted black and velcroed to the steering column (on top of a steadfast column guard).
Looks better than I expected and its very easy to read.
  Hardest part of the install is welding a bung to the downpipe and that was already done years ago.  I used a Bussman "add a circuit" fuse tap for power.
I learned a lot the last couple of years tuning the EFI on the '02 GS. Knowing what proper Air/Fuel Ratios (AFR) should look like, I can see right away the current electronic Quardajet is not doing a great job of maintaining the proper AFR. To begin, at idle, the AFR goes off scale lean and the engine stalls. At WOT, sometimes it goes very lean (bad), other times it goes very rich (good).
I'm going to tackle the idle AFR first. I swapped carbs with the '82 GN, which idles better and doesn't stall. The AFR at idle with this carb is about 16:1. Better, but the ECM should really be able to maintain 14.7:1 (the narrowband oxygen sensor is new by the way).
I did some homework and I believe I need to tweak the Air Bleed Valve. With a scan tool hooked up, the mixture control solenoid is reading a dwell of 6. Recommended is 30 (which would be 50% duty cycle). This is like zeroing out the baseline and having the mixture control solenoid right in the middle of the road, giving it the best chance of a maintaining the right AFR. As a engine gets old & worn, sensors drift, vacuum hoses leak, modifications are made (like changing the air filter box). All of this messes up the factory calibration baseline. An EFI engine uses long term fuel trims (LTFT) to correct the baseline. A carbed ECM doesn' have this. I believe tweaking the Air Bleed Valve is the way to correct the baseline.
I'd say this gauge, along with a boost and knock gauge, is a must have.
Now I just need to find some free time to mess around with it....
