I installed my rebuilt engine and want to break it in properly but cannot get it to start without giving it 1/4 throttle. It will not idle and runs like it is missing on several cylinders. If I pull a vaccuum line off and spray in some carb cleaner it smooths out.
I have 43# fuel pressure at the rail, I have spark at all cylinders, checked and reset cam sensor, new plugs and wires, firing order is correct. Injectors are new with matching TT chip. Verified injector pulse at each injector with noid light. TPS adjusted to .43 volts at idle
I dug out the old laptop with turbolink loaded but with the throttle being held open to keep it running I don't know if these numbers are meaningful.
Engine Speed 1525 RPM
Coolant Temp 154
Battery Volts 13.5
Loop Status Open
IAC 81
LV8 111
TPS 1.08
Int 128
O2 Volts 437 mv
MAF 31
Block Learn 142
O2 delta counts 111
Man Air Temp 59
Any suggestions would be appreciated.
Coolant Temp 154
Battery Volts 13.5
Loop Status Open
IAC 81
LV8 111
TPS 1.08
Int 128
O2 Volts 437 mv
MAF 31
Block Learn 142
O2 delta counts 111
Man Air Temp 59
