i just installed a FT roller. had all the proper clearances and lifter preload. good oil flow everywhere, good preassure. everything appeared correct.
when i first started the car everything sounded good. the idle was normal and the egine was surpisingly quiet. not barely any typical clacking from the comp lifters.
i went for a short test drive, maybe 6 miles and the motor started rapping. it doesn't do it at idle, only when it's revved a little. i took the belt off and ran it for a few seconds and it made the noise at idle.
the knock sounds like it's coming from the timing cover area. i'm pretty sure it's not coming from the valve train or bottom end. oil pressure is still normal.
any ideas? i was thinking maybe the cam gear? or something up with the balancer?
