installing a boost gauge.
ll3lue
hey i have a dual gauge apiller pod from autometer im going to install a 2 1/16 phantom boost gauge it goes to 30psi vac/ 30psi boost and i wanna know where is the best place on a 87 GN to tap the vac line???
i would search for this but the search feature doesn't seem to be working. :confused:
the vacume hose coming from the MAP sensor works, you can follow it by looking at the diagram on the vacum system in the engine bay
I would think the MAP line would be a good place to tap. There you have vaccum and boost, which is what you need.
