This isnt a Buick or a V8 for that matter. Its a turbocharged Corvair engine. I am either going to adapt a 84-87 Buick cam sensor OR use a sensor from a 5.0 Explorer. The Ford sensors came in 3 pin (Hall) and 2 pin (VR)
I am going to make a new aluminum body on the lathe to mount the sensor that I finally settle on and modify an existing Corvair distributor shaft to mount the disc for the sensor pick up.
So my question is this........
Is there any reason to use the Hall sensor over a VR sensor. I ask this as I have about a dozen of the Ford VR sensors sitting here that I could use, but no Hall sensors.
I have a Buick cam sensor top, but no discs.
Some good advice is greatly appreciated. Thanks in advance!
