When get ready to remove tank on drivers side rear fenderwell there is a plastic panel to the back upper side below filler neck. Remove this panel it will aid visually when removing tank so you can see where the filler neck will become logded in upper back corner. Instead of bending filler neck just tweak this sheet metal slightly and you will not have to bend neck. Not to hard of a job as I was told.
