When installing aftermarket speakers what is a good way to hook them up? I don't want to cut any of the factory wiring. Can I make some little jumper bundles - two male spade connector (to factory wiring plug) - wires - to two female spade connectors (to new speaker)? Or two male spade connector (to factory wiring plug) - wires - solder the wire the new speaker? Any suggestions would be appreicate.
How do you tell which wire in the factory plug is + or - ? I just want to make sure I hook the speakers up correctly.
Thanks, Craig
Thanks, Craig
