streetknight
DCVING
- May 26, 2001
I'm putting a NON lock converter in a car for my friend. I have the NON lock valve. Can I install this when I remove the pan to drain the fluid before I pull the trans out or is it better to roll it over on it's side on a bench?
Trying to save myself a step, figured I'd remove the pan to drain, change the valve, reinstall pan, pull trans, take the o ring off the input shaft and the thingy in the input shaft out and reinstall with new converter.
Can I do it this way?
