Am setting up a 109 block for the line bore of new steel main caps.
The 2 steel caps are .009" wider than the old iron caps.
Will the new caps need to be cut to fit the block ?
What is the amount of interference usually used between block & caps ?
Advice from anyone with experience setting up steel caps is appreciated.
