Does anyone know what the stud marked 16 in the diagram below should be torqued to. There is a 10mm hex on the stud and then a 15mm nut to hold the coil module bracket. The torque values for the stud and the nut should be different. I had a huge problem trying to un-seize the 15mm nut. A lot of heat and quench the stud and it finally broke free. I also have the same problem with stud holding the PCV tube bracket on the passenger side except the 15mm nut turns with the stud and the tube bracket so I can't remove it. I have been soaking with ATF and Acetone. Still no luck. I can't get a 10mm wrench on the stud hex and even if I could, I'd probably round the hex. Any tricks would be appreciated.
