SignUp Now!thanks brad
Anyone else can chime in too, looking for some good alternatives
Depends on the performance, and including visual goals.
Are you looking to go faster than low 11's?
Are you going IC'd?
Do you want to maintain the "stock look"?
Do you want to keep the turbo in the same location?
Yes for now I would like to go at least low 11's.
Yes on IC'd.
Don't care about stock looks, this is a driver not a show car.
And no the turbo is not going to be in stock location.
Well that is what I have now. I just welded an aluminum 90 degree elbow onto manifold. Stock Throttle Body is ok then??
I am planning on getting pt6776rh with t3 4bolt turbine housing .63 A/R. What kind of cam do you suggest?? This is a stock bottom end. Getting a 3-3500 stall too.
I know it's been over a year now and nobody cares, but has anyone ever tried this before, anyone see a drawback to this? the only thing I see is the size of the throttle body, does anyone know the size of a IC TB?
BEFORE
AFTER
Lets explore for a minute why this would not work. I see what you are saying, the flow to the thermostat would be off the coolant passage in the rear of the heads instead of the front. Would this be so bad? The flow of coolant would be from the water pump, around the front cylinders and be forced to the back cylinders, into the heads and out to the thermostat and onto the radiator, did I miss anything?
If you look at a lot of the NASCAR engines that pull coolant from the back side of the cylinder heads as a hot spot or steam pocket forms and causes the back cylinders to run warmer. This might have been were the idea for the LT1 cooling system was pulled from, it has factory steam pipes from the rear of the cylinder heads and come forward to the radiator.
Any Ideas?
