There are three bolts that hold the fan to a metal bracket/ring with nuts on the inside that you can't get to on the car. There are three 13mm (head size) bolts that hold it to the lower pulley. Remove these outer bolts and then tap the fan off with a plastic mallet (carefully). Or, pry carefully with a small flat blade screwdriver. They kinda press onto the lower pulley.
