If you mount it in the egine compartment between the radiator and the engine, then you need to convert over to an electric radiator fan...Be sure that you get the IC shroud from an 86/7 car and the ducting for the IC...You will also need to get the front air dam from an 86/7 IC car...I think they are still available from the dealer...
I have heard of some people testing a stock 86/7 IC mounted as a front mount IC...They flipped it upside down and ran the IC tubes under the radiator...I haven't heard any results of the test, but it should also work...If you do it this way and you run the IC tubes right, you may not even need to convert over to the electric radiator fan...
