Interior Lights--which fuse?
Purple87SS
YouTube Video Maker
Which fuse are the interior lights on??? They wont come on when I open the doors or switch them on manually?? Let me know thanks.
CIG/CLK fuse 25 Amp.
Also runs the glove box light, engine compartment light, trunk light and a bunch of other stuff.
hey real quick:
If my radio works, and none of the interior lights turn on with the switch or the doors open....
1- Where do I begin to look?
use the dimmer switch to see if the interior lights come on. If so try both doors to see if the interior lights come on. If they come on with either one of the options above, then you need to look at the door switch which when open completes the ground causing the lights to come on. Hope this helps.
