turbobusa69
- Sep 8, 2005
87 gn with stock ecm, recently after high boost pass it will stay around 2000rpm and not idle down. i was thinking bad tps so checked readjusted and doesnt seem to be that. i have scanmaster showing correct tps voltage for idle but still high idle. my next idea is bad IAC or maybe a loose throttle body blade. any other ideas? i have the good pcv with 1 way check valve so not thinking that but ??? also it will come down and have normal idle after abit but will do it again right after another 15-20psi or more boost pass.
what do you think
what do you think
