krisking94
- Oct 6, 2014
As the title states fuel pump wouldn't prime this morning. Previously I had found that my orange power wire was coming out of the Ecu connector, bought a new terminal and fixed that wiring. Did great for a while after that until this morning. Same issue. Previously though when the orange wire was the issue whenever it wasn't connecting the CEL light would just stick on solid when I powered the car on, so then I knew it wasn't connected. This morning the light flashed twice then stayed on as it should, indicating the Ecu is ready. Now idk if I'm relay is the issue, i have a spare to swap in and I'll try that later today. Now when I pull the relay off of the connector it has a bunch of black gunk in it. Is that just old dio grease or indication of something else? I will be checking the A1 fuel pump prime terminal to see if it is jacked up. I also need to check how much Volt is getting to the relay wire (black and green I believe) and I'll go ahead and check how much is getting to the orange power wire to be safe. Does anybody know what kind of voltage they should be getting? Also is there some sort of chart or pin point test I can look at to help narrow this issue down. Any guidance would be much appreciated, this car is becoming an electrical gremlin
