Fuel pump relay or bad ecu
Eddie M
Was driving the other day and car started missing every now and then. Finally it cut off and i found out the orange power wire had came loose from the computer. Got it back in and car started but was running ruff and throwing a 41 code (cam sensor circuit) unhooked everything and not the fuel pump wont prime. Ive checked the fuse at the hot wire behind the alternator and its good. Ordered a fuel pump relay today. Also when i plug the power back up with the key on the relay will click. Thanks for and info.
