SignUp Now!I'm not sure where the factory connector is.Do you have a pic of it?That's the only "kit", you can wire it by yourself. Just tie both grounds and powers together. Use a relay from battery/alternator and use factory harness as the trigger. Cheap easy and works.
Would you have a wiring diagram for this?theres also a plug and play on ebay from turbo89 but you really should run a pair of relays powered off the battery and controlled by the original wiring
Thanks for the info but I'm not using any of my original factory connections.i posted the wiring for the intrepid above
heres the factory diagram for the OE fan
http://vortexbuicks-etc.com/fan.htm
Thanks for pointing out those other options I was not aware of.theres also a plug and play on ebay from turbo89 but you really should run a pair of relays powered off the battery and controlled by the original wiring
the fan unit has a ground for each fan . tie them together and connect to ground (on chassis or pin C of factory fan harness connector)
the other wires on the interepid fans are green and yellow , power either one and you will get low speed , apply power to both and you will get high speed
so run green to pin A of the OE engine harness plug (low speed) and yellow to pin B of the OE engine harness plug (high speed)
the
i hate threads like this where the op doesnt give all the info needed for an answerThanks for the info but I'm not using any of my original factory connections.
The ebay adapter will most likely smoke your factory coolant fan relay and wiring. You can't run two fans with the factory relay. Period.
The Caspers harness is designed to plug and play for the Intrepid connector and it includes two relays. It was the original design for the conversion of the Intrepid (otherwise known as the "Ramchargers") dual fan. The Racetronix version is a clone - except - you need to splice in a connector so it's not plug and play. Apparently Racetronix couldn't source the factory Intrepid connector.
If you no longer have the factory connectors on your harness, then you're on your own for wiring.
Hello John,
I have your harness, but am not running the intrepid fans. Do you know if the fan side connector is available?
