Intresting propane article
They aren't even CLOSE to using up the potential of that fuel. With boost it would SCREEEEEEEEEEEEEEEEEAM!
Yeah, I am propane crazy. :p
I think we need to harass Bi-Phase to make up a kit for our LC2 engines :D
If they are getting 10-15HP from converting a regular gas engine to propane, imagine what it would be with a boosted engine going from 91 octane to 104 or 110 octane fuel that also cools the intake charge. Crank up the boost and you would probably see somewhere around 50-75HP on a bone stock engine.
Count me in:D
There is NO clinical proof that propane offers any significant drop in intake charge temperatures. NONE.
No clintical proof? Hehe, you have been watching too many comercials on tv..:)
True the propane injection we use works well since it causes a more complete burn once mixed with the intake charge. Vapor injection doesn't really cool the intake..
But what about when using it in liquid form? It's like -50 degrees Far. comming out of the bottle....
I don't really know, I'm just wondering, and if it really makes that much difference.
Even alchy causes a 20 degree (or thereabouts) drop in intake temps, but using it results in a couple hundred degree drop in egt's.It's all about what happens at the top of the compression stroke.
