IP pod pulling away from dash
jj86gn
Hey guy,
Does anybody know how to keep the IP pod from pulling away from the dash? The back part where it meet the dash is starting to curl. Looks like the glue holding the pod on is drying out. What can I do to reglue it and prevent it from happening again.
JJ86GN
P.S. My VIN check out in Car Fax so I know the car is not a basket case, just very high maintainance (brakes, computer, TCC sol, MAF, ETC, ETC!)
I would recommend you try to locate another one that is still in good shape. I don't think you can do anything once they start to warp and pull away from original shape. Many I see in the junkyard are still pretty good.......would just need to be sprayed to your color.
Before I went with this option, I asked a detail man for a local car lot and he said to try using Liquid Nails to reglue the pad back on. Guess what, It works.
Now I don't know how long it will hold but I'll let you know.
