is 79000 miles too much for a zq8
SmooveG
...to just bolt on and go or would they be worn out and need some brake service?
Huh?? Are you talking about an entire truck or just the brakes? ZQ8 TRUCKS use the same brakes as a bone stock G-body and the ZQ8 BLAZER/JIMMY built after the 98 model year uses the slightly larger rotor with the seperate hub and bearing.They also have rear disc brakes. I would assume if the hard parts look okay than put a fresh set of pads in and go. The bearings have some issues with them so its a crap shoot on whether they are good for another 79K miles.
