Is hood pad lettering vinyl or paint?
Wow......awesome work!! They do have a hi-temp grayish paint that i've used in the past and it held up quit well on my turbo shield for a LONG time. I believe it was VHT hi-temp gray. It's a pretty thick paint and might not 'bleed' to much into the pad. THANK YOU for all the work done so far!!
Ken B.
this is old news, i had a guy who was doing them for almost cost, the moderaters here were real cool about the hole thing too, they know he was'nt making any money of it, he was doing it mostly to help the guys out.
heck if correct g-body parts sells a kit. a couple of board members here have the hood pad, ( 1BADTT and ?? forgot his screen name :redface: ) looked good to. i need one also really bad.:cool:
be nice if the guy who did a run of them in this thread, .... http://www.turbobuick.com/forums/ne...-hood-insulation-pads-silk-screened-logo.html
could do a really big run and somebody like gbody or similiar could stock them, and sell them for around 200 (or less). up until gm stopped supplying them a couple years ago or whenever, they where selling them for $105. now thier around 125 last i checked with no logos. at least with stencils, you could buy blank pad, your own paint, and still be right around 200. personally i'd rather pay 200 or so for a new pad with the correct silk screen paint,... than bother with a stencil, but, gotta go with what you can afford i guess.
nice.. I don't have new one's to "die with" BUT Melissa has 2 :eek: .. I didn't know they have gone that crazy :rolleyes:
time is not on my side. I am very busy lately, being able to play more than one instrument is not always a good thing. everytime i think i'll get a evening to do some running around to talk to some body shops, t shirt making place, etc.. i get called to fill in for somebodys band. i did get some time tomess around with this today though. the stencil is done, there are a couple small differances from the original that you have to put one over the original to barely be able to tell. lets see how sharp your eyes are, i challenge someone to tell me the differance in the pics i posted. that is the original hood pad from my 84 gn. a run of these have not been done yet because we want to make sure they will indeed do a decent job. problem now is finding a suitable paint. since actual silkscreening is out of the question because it is a expensive process, i'm trying to find a suitable replacement that will not look like a cheapy rattle can painted over fabric. i've been doing some test here and there with some differant kinds of paints, trying to find a good "primer" to help take up the "porusnous" of the fabric before final color coat, you can see some of my experimenting on the hood pad.
a guy i work with who has done lots of silkscreening with ink on aircraft (mostly for labeling things), suggested trying out some differant fabric paints since they are made to soak into fabric and dry smooth, and then take a beating repeatedly in washer and dryer machine at hot temps. the only thing i've found so far that works really well is some stuff called stencil spray. its advertised right on the can as "silk screening in a can". google it, your local arts and crafts store will probably carry it. only cost about 4 or 5 bucks. dries hard, and it leaves a nice crisp clean edge when i pulled the masking tape off to see if there would be any bleed. i'm sure there will be some bleeding here and there, but you could touch up with some black touch up paint or marker. problem is, i want a closely matching grey or silver color like original. they make it in grey, but it has lots of glitter in it. its just to much and doesn't look right. they also make it in white, but i don't want white, as soon as some dirt or grease, oil, etc gets on it, i would think its going to look dirty even if you wipe it off. they make it in black, so what i'm going to do is do a first coat of black, let it cure, then paint over with a regular light grey, probably a hi-temp light grey. i hope to get this done this week and post some pics. i've tried regular sandable primer, and it doesn't fill "flow" into the fabric very well.
Those look really good. I think the only difference I noticed were that the edges of the letters in the word BUICK were more rounded where as the originals were more square. What I was thinking of trying to use for paint is some of the high temp engine ceramic enamel paint as they sell a silver that appears really close to the original color. I think that if you were to use that and go over it multiple times in very light dustings almost not spraying it at all with time to dry during each layer, that it would not run and that it would adhear very well. Pluss being ceramic enamel it would hold up to the heat very well. Please let me know when you have a stencil ready for purchase as I am eager to try this out. Thanks Dusty
I started the process on my brand new hood pad last night, everything was going well until I sprayed the stencil spray on. for some reason it started to lift the stencil inbetween the letters. :confused: When i put the stencils on, they all went down nice and flush and adhesive held well. So all i got was a first coat down. I abanded the black stencil spray idea because it just didn't leave as good of hard surface as the silver glitter, so i was going to go over the silver glitter stencil spray with a light gray high heat. I couldn't put another coat of anything on because it would look like crap. Everything else looks great though. edges are all nice and crisp, this would have been absolutely awesome if stencils hadn't screwed up. you'll see what i mean in the pic. at this point, i'm so freakin busy that i may abandon the project. plus, i'm on a diet, and by the afternoons i'm feeling so weak and pissed off that i don't even feel like messing with anything. :frown:
I'm going to talk to the guy who originally had the stencils done and and see if there are some stencils with better adhesive or similiar that i can try.
I could try and overlay another stencil on top of what i've done, but i'm afraid i'll lose my crisp edges, then pad will be junk. speaking of which,... i just got this pad in a couple days ago and paid $150 for it, i kept the shipping box it came in, if somebody needs one for a driver, make me an offer i guess. :rolleyes:
Here's what I had done to the underside of my fiberglass hood...I wanted to keep the stock appearance, so I had a letterer take the measurements off the stock hood's underpad and then he used these measurements to make himself a stencil to letter the underside of the hood, using some letterer's "One Shot" paint, silver colored...Looks ok...:wink:
Claude :smile:
