Is it ok to drill bigger holes in sway bar?
ross87t
I bought some BMR LCAs and they seem to require bigger bolts for the mounting of the sway bar. Is it ok/safe to drill bigger mounting holes in the stock swaybar to enable a larger bolt to fit?
Thanks,
Ross
I went home and did some measuring. I'm going to need to drill it out w/ a 9/16" drill bit, which looks like it shouldn't be a problem.
I should have done the measurements before I asked the question. Seems a little silly now.
