I have a 1986 GN with around 108,000 miles on it. I'm using the factory suggested 10w-30 and have about 70 psi oil pressure when cold, but once it heats up the pressure drops to only about 17-18 psi. Should I switch to 10w-40 or 20w-50?
The manual in my (87) says 5-30. Only used 10-40 from the start.
Back in the day Kenne Bell I would say was the big guru and always used 10-40 and recommended it.
And the 10-40 today is way better then 40 years ago
All those 6.2l engines GM has to recall use 0-20. One of the changes will be to have owners switch 0-40 or perhaps
5-40. Hoping to push it over the warranty.
I guess if you're buying new today you pick your poison and hope for the best.
