just wanting to confirm that the pedal for the 84 hydraboost is the exact same as the 85-87 powermaster. i heard only the vac boost cars from the na g bodys had the differant pedal.
I installed a custom kit. It was expensive by anyones standards, but I am happy with the way it performs. There are plenty of less expensive Hydroboost transplants that a few members have used. I just got tired of the Powermaster headaches. I wish now that I had given the Vacuum system a try first. No regrets though.
No the factory manual brake pedal is not the same. The PM/HB uses the same pedal and the manual brake used the vacuum brake pedal. If you look at the vacuum pedal you will see a hole right above the pin for the booster rod. This is the hole that GM used to weld the pin for the factory manual brake. You could probably make your own pin using a bolt and drilling the hole for the retainer pin and welding it in place. I don't have any idea what people are using for the home made set up. I've seen some scary looking set ups out there. I'd think twice before I would bolt on a MC to the PM mounting bracket.
