I had the same problem when I did my conversion as well. Turned out to be my check valve was not good and neither was my vacuum source. So I bought a check valve from Summit, made up a Russel line, Taped my intake spacer and hooked it all up. Brakes work excellent now. Better then I expected. See pics below.
Summit Check Valve
Russel Line
Hook up to the check valve
Hook up to the Motor
I've been getting a bit of mixed information... My dad tells me that the pedal goes to the floor like it does because the cam size/valve duration doesn't allow the motor to create as much vacuum. My uncle tells me that if it was a vacuum issue, the pedal would be hard, not soft.
When I block the vacuum line, the brakes get hard. This car has a Wilwood brake system (m/c, 4 piston calipers, drilled and slotted rotors 10" up front, 12" in the rear and stainless lines). I don't know what booster is on it, the brakes were done by the previous owner. I checked the brake fluid and it looked more like old motor oil (very dark), so I sucked the fluid out of the reservoir, cleaned inside the reservoir with a clean dry rag and flushed the system with new fluid by bleeding each of the brakes until the fluid looked clear. When I was bleeding the brakes, I never seen any air.
The boost gauge reads about 10-13psi of vac at idle. When I pump the brakes repeatedly at idle, the RPM drops and it sounds like it wants to stall almost but never does no matter how fast or how many times I pump the brakes at idle. I did this after having just started the car, but I don't think it was fully warmed up.
The vacuum is coming off the distribution block on top of the dog house/upper plenum. It has the vacuum block for the vacuum brakes. Where were you getting your vacuum from before you moved it to the spacer plate? This car also has that same spacer plate.
How do you tell if the check valve is bad? I tried to blow thought it and it only allowed air to flow one way, but I'm not sure if it takes more pressure than that to test it. When the car off and having sat for hours, I pull the check valve out and can hear air.
I'm thinking I should take it to someone that can vacuum bleed the brakes, really flush the system and test the m/c to make sure it's working properly. The pads aren't that bad, so I'm pretty sure they aren't the cause of this problem. There are no fluid leaks from what I can tell.
I can make a video of this car and the issue if it helps.
Can you please explain how low vacuum would cause this problem?
