transampacecar
- Apr 30, 2005
Newbie trying to learn, hopefully not the hard way by breaking something.
The TTA is stock (and I would like to keep it that way, but dont mind bolt ons) except for
1. 160 degree thermostat
2. Adjustable Fuel pressure reg
3. Mild chip set for 93 Octane done by Caspers.
4. K & N filter in the stock air filter box.
I have adjusted the actuator and the boost is 17 lbs.
1. Scan master reads at WOT in 3rd gear, 864 for the 02 and 3.3 knock.
2. The fuel pressure gauge is set ot 47
I did not record yet the other readings in Scanmaster, but trying to find out if the above readings and fuel pressure is a problem.
What are any suggestions as to what I should change, upgrade, tune, etc.
Also, I just ordered a Walpro 340 and Hot wire kit, but I assume that is not going to change any of the above.
