Is propane jetted?
What's the smallest jet that you should run? I have a .032 and a .030. And what pressure is the best to run? This is on the GTP. Thanks Tim
I didnt know we were sending out jets that small with our kits. What size jets did you get or what kit do you have if it isnt the OGS?
Pro-Pain comes with size 70, 76, 81, 86 & 93 jets IIRC. Personally, I think that they are all too small... I might try running without a jet in place. ;)
*Jay, how is my chip coming? ;)*
I actually made the kit myself. I'm using a NOS jet and switch with a pressure activated switch set at 9lbs and NOS feed line with a adjustable regulator at the bottle. I'll see if it works tomorrow. I just had some small jets left over from an alcohol kit. Thanks Tim
