A little background....
Doing some tuning the other night, 17psi, 21 deg timing, 10.8 afr, 94 octane and meth. No knock. 3 Egt's less than 1370 degrees in the passenger header ( driver side need relocation before use unfortunately.)
Heard a small pop and a weeeeee noise, followed by a loud exhaust ticking noise.
Felt around the header, no leak felt. Sounds higher up.... Looked at rocker adjustment, nothing has moved with all pushrods right where they were before.
Compression test 150 for all clinders except for #5 which is 125. Here is a pic of the plug.
Diagnose away!
Diagnose away!
