Is there a way to average readings on the PL?
Blazer406
Mechanical Engineer
On a XFI... you can select and drag across a portion of the datalog and it will give you an average reading for the range you had highlighted. If used correctly.... you can get a good idea of how much correction the chip/ECU was doing for that portion of the datalog.....
Is there a way to do this with a PL?
not directly
what are you trying to average?
I was wanting to take the portion of the log that was at WOT in high gear and see what the average BLM was for that portion of the log. I can do it manually.....no big deal..... I was just trying to hit shift and slide the bar over and make it highlight a small portion of the DL....
that would be a cool feature, unfortunately it would take quite a bit of work to implement. There are ways to do what you want, however.
Bob
