Is there an ideal piston compression height?
Squid4life said:
Thanks for sharing your specs Allan, much appreciated.
3.59" BMS crank
6.5" Crower Ti rods
New JE pistons, as long as they measure right
Guess I need to buy rings and bearings and get this thing together.
Any suggestions on rings or bearings? TA for all bearings? I want to say those pistons are cut for metric ring packs. Any suggestions on those?
Looking at my notes I used CB1398H rod bearings and 107M for mains.
Rings were JE p/n JG3101-4000-7
Check and see what size rings you need and make sure they are the same size.
AG
AG
Your using standard molly rings.....ewe....o_O
I'm not so sure its a standard molly ring. But if it was its better than you running standard GM valves.:p
AG
Allan, my motor is a test mule in the car now...it has moly rings also, the rings I want only come in 4.00 and larger bore sizes. Nothing wrong with moly , but I intend to run big boost:: on the next build. Please read the pdf file and determine what works best for your application.
http://www.federalmogul.com/tec/docs/1210.pdf
